Engine Changing Tranny Fluid for MT
Discussion in 'Powertrain' started by Addicted2Boost, May 16, 2004.
    Addicted2Boost Guest
    I know this has been posted before, but I was hoping someone had a picture of the drain plug and where to put the new tranny fluid in. Please help
    Someone should post a DIY
    dvsj Guest
    David K. (KingKuei - the guy who helped install your exhaust) was going to change mine, but I changed my mind. He can help you with that.
    BTW...did you get my email?
    ok.. cool
    I did get your email, I am waiting to get access to my Paypal account. I will transfer to you as soon as possible. Sorry for the delay.
    Rich
    CorollaAltis New Member
    the drain plug is under the tranny. its a 24mm bolt. the fill plug is here
    that from the engine bay view looking down
    KingKuei Guest
    The drain plug is mounted sideways on the tranny. The purple circle in the above picture is the fill plug, as indicated. You have to get underneath the car to get access to the drain plug though. If we call the fill plug the FRONT of the tranny, then drain plug is on the DRIVER SIDE of the tranny. Same 24mm hex bolt.
