Changing stock stereo LEDs...?
Discussion in 'Interior' started by unioncorps, Feb 18, 2005.
    unioncorps New Member
    I'm thinking of keeping my stock stereo in my car but the thing is I don't like the nasty green backlight to it. Is it green LEDs behind the screen? If so, how would I go about changing them out? I'm thinking of putting a white LED so the backlight would come up white with black text (as usual).
    DjFrOsT New Member
    Los Angeles
    I wanna do the same thing...
    i had the same question...
    Laz Z Kay "n00B, be kind"
    Biloxi, MS
    That's lots of work. You need to solder lots of LEDs. About 30~40.
    laz Member
    NYC
    i've done it before:
    It took me a good hour and a half and it had like 30 super small surface mount led's.
    What I did was get me an extra stock radio from ebay for cheap in case I messed anything up, and I ended it using the parts from it since I managed to crak my LED display while doing the work. You first have to find out what size LED's you need, then you can go to www.mouser.com and match them by size. Do not get the extra bright ones since I didi that at first and I had to swap them with regulsr ones since teh extra bright ones where too bright.
    I know people with celicas have donethis as well.
    GL
    X
    Biloxi, MS
    I've also seen someone did on on a 9th gen too. A 2 tone, white and blue. Cant remember where I saw it, otherwise I would forward you there.
    DjFrOsT New Member
    Los Angeles
    ummmmm....that sounds like alot of work... :cool: ...
    Cape Coral, FLorida
    what about after market headunits? i have a pioneer that for some reason is the same green color as the stock 1 it looked good when everything was green but the rest of my lighting is now red
    ArdotheWan New Member
    Torrance, cA
    Not worth if to me to change a stock stereo, just get an aftermarket that matches the light scheme you want to go for and change the other lights... casette players suck anyway
    NRM NRDADDY > YOU
    Whoa whoa, you can change the clock color?
    I have a blue face on my HU and I was meaning to changing all my bulbs for the AC and stuff to blue, but I was paranoid about the green clock.
    Anyone have any instructions on how to go about it?
    Cape Coral, FLorida
    u can get a transparent colored film
    Azn_SpICe New Member
    my thoughts and exactly what i wanted 2 do!
    NRM NRDADDY > YOU
    Doesn't that mean I have to find a way to mix the light to come out with blue?
    Green + What = Blue?
    I never remembered this in art class.
    actually that is a good idea... where can i get that transparent film and what color would i need as he said ^
    CraigW New Member
    Crafts store / translucent binder from office supply store.
    NRM NRDADDY > YOU
    Well, the only problem I see with transparent film is that if you have any dust (inevitable) between the tape and the plastic on the clock, it's going to show like a mother especially at night. Since the light is going to be reflecting right into it.
    I don't mind changing LEDs, I just don't wanna open something I'm gonna break. But if it's the only way...
    CraigW New Member
    The surface mount LEDs would be a real challenge, of course still possible.
    Cape Coral, FLorida
    sum1 on the old vvti used this stuff called rubelith the stuff they use to cure photos, and he actually opened the clock up and put the film behind the clock (it was red) and it came out perfect no dust and he didnt have to match any colors
    Torrance, cA
    ya thats what i used (rubilith) put it right on the clock piece... ill take a pic and post it tomorrow
    laz Member
    NYC
    I opened the clock and did red cellophane. It came out good. Of course if you want blue thatn that is impossible since you would need to change the LED display to a white one to get blue.
    X
    SD_S New Member
    SF, CA
    my method was open the enitre clock and added the red transparent colored tape made by 3M on top of the screen and the put everything back together and there you go :) your clock is now red. I will try to post pic if i get a chance.
