Engine Changing starter 7AFE, question
Discussion in 'Powertrain' started by killer2239, Apr 2, 2005.
    killer2239 Lift at 5700rpm
    Lexington, KY
    I looked in my haynes book and it seems fairly easy to replace. I know toyota wants lots money to replace it. But id rather do myself if its pretty easy. According to the book, you just undo few screws under intake manifold, and take out. Is it pretty easy from any of you that have done it?
    I thought it was the clutch switch, but its the starter.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    hope you have small hands, lol, i remember when my 95 was my sisters car i helped my nieghbor change the starter, it was a pain, i think its easier to drop it out the bottom if i remember
    turbo4age Love to Hate me
    NV
    it should be two long bolts holding it into the trans (bellhousing)..... undo those and it should slide right out
    Lexington, KY
    Thanks guys, ill be doing it monday morning probably. Unless autozone is open tomorrow.
    toyotaspeed90 New Member
    Bellingham, WA
    schucks/checker/kragen will be open tomorrow..... so are most napa's (until 4)
    in any case..... it would be easier if you remove the intake support bar.... there is one bolt on the back of the starter and there will be one on the transmission side..... then just disconnect the 2 wires going to it (make sure you disconnect your battery first!!!)
