center ring for aftermarket wheels
Discussion in 'Stop, Drop & Roll' started by CorollaULEV, 2004年11月17日.
    CorollaULEV Guest
    So I had a set of American Racing Estrella 15x7.0" rims on my 90 Camry when I had it. They've been on the Corolla (2003 CE) since I've had it. However, the center bore of the wheel is larger than the center bore on the hub. I need a set of the center/hub rings so the lugnuts won't be what's holding the wheel in the center.
    Any idea what the stock center bore diameter is? I think it's 54.1mm - can anyone verify this, I'm too lazy to take my wheel off and measure right now.
    Does anyone know off of the top of their heads what the center bore for the rims are? It's a shot in the dark, but someone might know.
    Where the hell can I get these anyhow. The resources on the internet are limited.
    Late,
    Trav
    DC Stewart Guest
    They are available at any good tire store. They're called Hubcentric rings and are about $4 each here in Canada.
    CivicEater Guest
    <a href="http://www.discounttiredirect.com" target="_blank">www.discounttiredirect.com</a><br />
    <br />
    just call them with the wheel model and the car model and they'll ship you ALUMINUM ones <img src="http://vvti.net/forums/images/smilies/wink.gif" border="0" alt="" title="Wink" />
