Car Wont Start - Makes a Muffled sound when cranking
Discussion in 'General Discussion' started by rolla_dink, Mar 27, 2004.
    rolla_dink Guest
    Car Won't Start - Makes a Muffled sound when cranking
    Went to start up my car tonight, but it only cranks and makes a muffled sound. Could my MAS be dead?
    methaneb Guest
    Unknown due to lack of input. If in warranty (or not) it sounds like a dealer issue.
    rolla_dink Guest
    ECU Died
    the dealer says the ECU died. Sad day. I'll w/o my baby for a couple of days. :(
    RexPelagi VDub
    Canton, Ohio.
    Isnt the car alittle new for the ecu to die?
    TRDFAN Guest
    I'm surprised they didn't blame it on your intake. I hope you get it fixed man. Good luck!
    rolla_dink Guest
    Luckily the intake was taken off when I had the S/C installed. Unfortunately the Injen Intake will not fit with the S/C. I should probably sell it and get the AEM or TRD, they are the only ones that fit.
    On another note, I'll have to ask them what fried the ECU. Make me worry if it can happen again. Could have been a bad wire on the S/C install, who knows. That was the last thing I had done to the engine.
