Car of the Year!
Discussion in 'General Discussion' started by DaCubanSkillz, Nov 22, 2006.
    DaCubanSkillz Active Member
    i'm just waiting for the camry to get a facelift. whenever toyota comes out with a new look, the redesigned facelift they apply a couple of years later always looks better.. maybe then i'll consider a camry hybrid..
    The camry was redesigned. the 07 is nothing like the 06.
    Paolino SolidTuned
    RAF Molesworth, UK
    Screw the hybrid. I want the 3.5 in a manual. :) (With a TRD S/C kit to put it up to 300-310hp)
    Tulsa, Ok
    I think it well deserved it...
    BLADDER_MASTER Active Member
    FL
    Camry SE for me plz. I heart that thing.
    01rollas New Member
    just give me a camry V6 and a S/C and i will be set
    D Matrix Member
    Cleveland Ohio
    you and me both
    YamahaTundraV8 New Member
    Atlanta (burbs)
    yea but the former Styling is much better on the 02 to 06 I dont care for the Big huge grill with that looks like a Tooth Emblem on the front end otherwise The Camry rock's on everything else..If I was in the market for a car I'll get the bigger Toyota avalon Xls which is based on the Camry just bigger..
    Do you miss your Tc ? My brothers both have 2006 Tc's and they both ride and handle pretty well but the engine to be is rather slow..
    I miss the tC at times. I'm not gonna say its a bad car cause it wasn't. But it could of been a bit better. I like the Camry because its much more comfortable. Once I get my TSB done, the hesitation issue should be gone so I should be good to go.
    01rollas New Member
    the camry over here is popular among the "small car segment" since its overall length is smaller than that of the Crown Majesta which can range from the same size of the USDM camry to longer than the Avalon, depending on tirm level.
