Car Alarm Question
Discussion in 'Interior' started by phillipguru, Jul 14, 2005.
    phillipguru Guest
    what year is your car?
    statik New Member
    Ok, a 2002... You can put it up in the far left side of the kick panel. You'll see a hub with connectors for your speakers there, right above that there is a small cavity that you can fit it into. It's almost hidden.
    phillipguru Guest
    <br />
    Woot, you beat me too it, there is where my 02 alarm is installed (aftermarket) i would say in that spot or mount it behind the dash to the firewall
    -Goku- Guest
    so the kick panel it is. Thanks guys, also my friend drilled 2 holes for the siren up on the fire wall. Would he have hit anything with the screws????????? also he punctuered the Firewall Insulation to get 2 wires through. Is that going to be ok O_O Also do you just mean shove the brain in the kick panel or mount it? I don't mind just putting it in there.
    -Goku- Guest
    Car Alarm Question
    Where would be the best place to put a Viper Alarm Brain in a 2002 Corolla? My friend put it up buy the steering Column but i have to have him move it because its hitting and he zip tied it to the AC/Heat Vent. plus where is the Siren suppose to be mounted?
    Any Help on this would be very Helpful
    Thanks,
    |-Goku-|
    phillipguru Guest
    <br />
    It should be fine, what i would do the wires through the punched hole is get some high temp silicone sealer and completely cover the hole and fill it in, after it sets it will become a pretty decent seal
