Can the brights be seperately adjusted?
Discussion in 'Exterior' started by willemv, Jul 1, 2004.
    willemv Guest
    Hallo All,
    After the service my Dim lights were perfectly adjusted, but the brights are well out of alignment. Can the Brights be seperately adjusted?
    Thanks,
    WillemV
    brownbanana ToadMotorSports
    Oahu, Hawaii
    cuz22 Guest
    man u should check your light fluid loll j/k
    DistantXtremes Guest
    Re: Can the brights be seperately adjusted?
    in short no.
    if you take apart the headlamp you can see that the high beam and the low beam reflector is one piece.
