Cambers are off with h-techs
Discussion in 'Stop, Drop & Roll' started by cmybootoo, Jul 19, 2004.
    cmybootoo Guest
    went to the alignment shop today to get an alignment. they told me that the front camber were at 1degree and that the backs were at 1.5 degrees. Does that sound right. I do notice some premature tire wear up front but the backs seem perfectly fine. So what do i do...get a camber correction up front and leave the back or what??? :?
    APC_MATRIX_ Guest
    Re: Cambers are off with h-techs
    If they did a "thrust alignment", that means that you actually have -2.5 degrees of camber up front. A thrust alignment goes off of the back tires for specs so I had a reading of -0.7 degrees up front and my back is permenentely at -1.5 so that makes me at -2.3 degrees of camber up front.
    That sounds right if it's a thrust alignment, go ask to make sure though :wink:
