brake pads?
Discussion in 'Stop, Drop & Roll' started by tehloxely, Sep 8, 2004.
    tehloxely Guest
    brake pads?
    Hey guys, what brake pads would all of you guys reccomend using on a 99? And where you can get them? I'm in dire need of new pads. thanks!
    d_samurai Guest
    oem toyota pads...non shall worketh better than toyota...
    tehloxely Guest
    I have the ones that came with the car and they squeek! That's why I want new ones... heh.
    d_samurai Guest
    how long have you had em for? squealing is an obvious sign of wear and tear...so new pads- no matter what brand will be quiet (for a short while)...BUT, some cheap brands will squeal earlier than others... also- make sure your rotors arent too deeply scared and that they are properly surfaced...
    03silverrolla Guest
    you could try and clean off the rotors too possibly with brake fluid
