Brake lights don't turn off
Discussion in 'Interior' started by SK149, Jan 25, 2010.
    SK149 Well-Known Member
    Miami
    Ok so my brake lights won't turn off at all unless the battery or fuse is taken off so my brother in law said it's the brake switch but I can't seem to find it in my 99 corolla so any help would be great. Thanks ahead of time because I know you guys are good lol
    nyrican52884 Active Member
    Plymouth, MA
    First check the pedal. This happened to my girlfriends car, and when I lifted the pedal the brake lights would turn off. There is a switch under the pedal that is held in by a nut, so I loosened the nut and adjusted the sensor, and then tightened it back into place. Never had the problem again.
    Rincon , Puerto Rico
    Brake light switch is melted in the on position :)
    Do the brake lights turn on with the parking light, or all the time? Check your bulbs and make sure that they are not melted funny...
    Miami
    well when I lift the pedal the lights still stay on
    ok so where is the brake light switch
    they always stay on unless the battery is removed or the stop fuse is removed
    CDD New Member
    Lost
    There is also a rubber type of cushion that makes contacts with the switch to turn the lights off.
    Its either the switch going bad, the rubber cushion fell or brake or lights gone bad.
    To see the brake switch you will have to get under the dash and see ( use a flashlight) look for where the brake pedal come to a stop ( not press) and it would be in that area
    Scanned Info from Repail Manual 2 Files: one is the switch location the other a switch test
    LINK
    Miami
    Code:
    Thanks for the info I shall look into this after work
    Take your damn foot off the brake!
    Then don't bitch about your brake lights!
    Whose bitching?
    What a bitch.
    Get out of here bitch!
    I cant, i'm trolling.
    Like a gold.
    TOUCHING
    One word post fails.
    :DAFUQ:
    OWPF
    Courtesy of:
    --==[TEAM HIGHER STANDARD]==--
    Team same post everywhere.
