Braille Lightweight Battery, rebadged. deka
Discussion in 'General Discussion' started by sean2sean, Oct 12, 2006.
    sean2sean Member
    so cal
    I've heard those batteries don't store a whole lot of total energy so they're only good for maybe 2-3 starts before they run out of juice. (have to rely on being recharged every start) other than that it's probably a good way to reduce weight if needed.
    personally I'd just move the stock battery to the trunk in our cars for better weight distribution
    sean2sean Member
    so cal
    lol... i tried doing that... using 0 gauge wire. it adds even more weigh to the over all vehicle... maybe about 10 more lbs... due to wireing...
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    0 gauge? Damn, you only need 4 gauge.
    ghoztrider New Member
    Suburb of Philadelphia, PA
    if u really want a 2 battery setup i'd do it the right way and just put 2 optima yellow tops and connect them with either a 4 guage or a 0 guage... Depending if i can 0 guage good, most likely 4 guage and make sure i ground the 2 batteries really well
    or 2 energizer batteries like the one i have that have the same power rating as the optima except for CC which is 20 less
    most shops around here just use a Hawker odyssey motorcycle battery for the track cars.
    sean2sean Member
    so cal
    no single setup. weight reduction. not to add weight.
    metlife622@yahoo.com Banned
    i see hondas use a small little optima battery, are those the same as stock?
