Engine BOV's Question
Discussion in 'Powertrain' started by Coryolla, Jul 11, 2004.
    Coryolla Guest
    BOV's Question
    Ok me and my friend are arguing about BOVs on superchargers... I said it doesnt need it... he says he heard it, i told him it was a turbo. So can somebody verify?
    CadetLee Guest
    Superchargers are belt-driven and run at a constant pressure, afaik..so no BOV.
    I'm no expert, though. =)
    third that
    turbo4age Love to Hate me
    NV
    the superchargers that dont need/have BOVs typically have the throttlebody placed before the supercharger unit, thus there is no way for air to back up into the blades. i.e. roots/twinscrew/whipple that mount directly to, or replace, the intake manifold..... similar to the trd one for the corollas
    a centrifugal is basically a belt driven turbo and mounts before the throttle body, therefore when the throttle is closed the pressurized air in the charge pipes needs somewhere to go........ BOV
    I believe turbo4age said it best,
    but i was thinking since the engine revs slows down after the throttle is close, there may be no need for a bov... but then again same could be said for turbos so tuche
    Turbo4afe Guest
    what jspexae102 said..
    slvr2000fdvspec Guest
    some superchargers have bov's..i heard them before..unless i was dreaming
    it depends on the supercharger, it is quite possible to put a bov on a centrafuge type since there are charge pipes leading up to the throttle body, and it would "blow off" when you let go of the throttle at high RPM's.. but rather or not they're needed is questionable
    XS PSI New Member
    yea what turbo4age said...
    Coryolla Guest
    ok so its a possibility?... but not exactly needed...
    Concordmk1 Guest
    ditto, possible, but essentially pointless
    Turbo4afe Guest
    its only possible in a belt driven one, that has thorttle pipes...
    its impossible to have one at a supercharger that mounts on the intake manifold like the 4agze.
    NV
    so i take it nobody read my post?
    superpilun Guest
    even so BOV's are not technically required even on turbocharged vehicles. whether or not compressor surge is bad is debatable.
    NV
    thespud Guest
    BOV's on superchargers are a possibility, and may be needed in some cases... for example in a twincharged situation, when the turbo spools, it opens the BOV, to reduce backlash and mechanical drag, but these are usually only required on centrifugal types..
    NV
    reading is fun
    thespud Guest
    I did read that... i was just clarifying...
