Forced Induction bore?
Discussion in 'Powertrain' started by vg30dett93, Jan 9, 2006.
    vg30dett93 New Member
    jax,fla
    bore?
    I was just wondering. how much more power would I get if I bored my 1.8 to a 2.0? and would there be any problems?
    JLee TD05 3SGTE
    NH
    Not enough to justify the cost - turbo it! ;)
    indeed, if youre going to bore to 82mm then you need to just drop the comp and turbo it. going N/A would be okay, but you're going to hit road blocks with the higher comp.
    Shifty SIdeways Noob
    Memphis,TN
    Don't listen to all the boost heads...
    Stage 1: 268/260 duration, .374/.347" Crower Cams, Crower Spring and Retainer Set, MWR Toyota 1ZZ-FE Piston and Sleeve Kit 11.0:1 - 82mm bore 1.93L,MWR Valves,Crower Billet Connecting Rods,MWR GReddy e-Manage Package - Toyota 1ZZ-FE NA Preprogrammed
    JLee TD05 3SGTE
    NH
    I have no idea how much power you can get out of a n/a 1zz..but I'm guessing you're making ~155hp / 150tq. Am I close? This is assuming what you listed in your post is what you have in your car..I dunno..
    yeah good idea, more money for less power than turbo :(
    Sounds pretty reasonable to me - that is what MWR is advertising (+10-15% gain) for typical gains on a 82mm bore (hair under 2.0L).
    hehe no kiddin
    12055 New Member
    woodbridge, va
    I would like to know your output too shifty, and the powerband that is used.
    Memphis,TN
    Lol, I dont have all that stuff, just postin it to show if you did wanna go N/A parts to buy...
    hehe didnt mean to start the big n/a vs. boost debate.
    jax,fla
    What about both?bore then boost
    Memphis,TN
    You would have more horsepower/torque than someone who just boosted without boreing the engine.
    Barnacules 100101101011011
    Duvall, WA
    Both would be ideal! :) More space = More Air = More Fuel = More Zoom! I beleive that is the formula. If you got the money that is the way to go for sure. But if its one way or the other then go boost, I just turbo'ed my Corolla and my car is scary fast now and I'm only at 8psi of boost. Its nuts. And if you have a small turbo the power band kicks right on and hard.
    jax,fla
    well first of all I was thinkin s/c, but I just dont wanna wait for no adapter kit. So then I was thinkin turbo, i know hass has that kit. Then I was thinkin what if I went 2.0 then turbo.:D . I'm gonna be comin up on some money next year for the kit. So this year im gonna work on the engine. So im makin some plans.here in jax everybodies boosted. It sucks..
    dude
    the hass kit is good for 03+ corollas
    it advertises 266 whp on 8psi with intercooler on a stock 1zz.
    noice, but it's 4 grand -_____-;;
    polo708 New Member
    9thgencorolla.com
    just buy a built motor from mwr and get it over with, haha... $4000 and your practically done.
