Engine Boost
Discussion in 'Powertrain' started by JDM COROLLA S, Oct 5, 2004.
    JDM COROLLA S New Member
    Boost
    I have an 03 s/c how can i get more boost. I know someone changed the pulley on the supercharger how do you regulate the fuel? Anyone done this?
    polo708 New Member
    9thgencorolla.com
    Im running water/methanol injection, works like an intercooler if you dont know what it is. An intake will up the boost a little too. if you change the pulley you need some kind of cooler system because it will run VERY hot... pushing about 10 lbs of boost with the pulley and intake.
    94rolladx Guest
    you can use a apex SAFC(2), it will control the injector pulses, and a vortech FMU will controll/increase the fuel pressure, in proportion to the amount of boost you are running
    lonelydriver New Member
    the unichip is probably ur best bet.
