Forced Induction Boost Sensor
Discussion in 'Powertrain' started by Barnacules, Jul 9, 2007.
    Barnacules 100101101011011
    Duvall, WA
    Boost Sensor
    My Greddy eManage boost sensor failed, it now is stuck at 29psi and wont seem to budge more then a psi or two in either direction. Can I tap the sensor wire from the emanage harness off the Apexi AVC-R boost sensor so I only have one sensor in the system?
    LoSx New Member
    Well technically the avc-r I believe runs off a 0 - 5 v sensor like the emanage the problem is that moltage may not line up...
    the apeci may be a 2 bar system while the emanage is a 3 bar system...
    I believe there are cheap emanage boost sensor (not sold by emanage) but by GM or something that you can find around.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    GM ones are the ones my friend use on his turbo honda builds
    Duvall, WA
    Any idea where I can find the 3 bar GM sensor? I would like to buy one and get this bad boy back on the road again :)
    SaberJ2X Lurk MOAR
    Mayawest, PR
    junk yard? some generic auto part stores
    just ask for a 3bar GM map sensor I think they are 3 cables
