Engine block heater...
Discussion in 'Powertrain' started by CorollaULEV, Dec 15, 2004.
    CorollaULEV Guest
    block heater...
    Are there block heaters made for our cars? Are there universal block heaters that would work. A search on the net yielded nothing....just curious.
    Late,
    Trav
    dominator 04 Rolla 5spd.
    The block heater is available from your Toyota dealer... It's a dealer installed exterior accessory for $154.00 (Cdn) in Canada.
    93corolladx Guest
    Mine came with one from the dealer, 1993.
    statik New Member
    You woun't find a generic heater for it. Gotta go to the dealer. The dealership sold mine for like $60 or $70... It's easy to install.
    SkyAce2004 New Member
    what exactally is a block heater
    It's a 110 volt plug-in electric heater element in the engine cylinder block that warms up the coolant to reduce strain on startup in freezing weather.
    Click on 'EXTERIOR', then 'Block Heater' for pic and details; http://www.toyota.ca/cgi-bin/WebObj...c920000e%2ehtml
    Live2drum New Member
    ya that would freak me out if i found a plug in my car
    whoa, u plug it into ur house???
    93corolladx Guest
    yeah theres an outlet under the radaitor, i was confused when i first found it
    statik New Member
    Hahaha... you guys are funny. I was the same way at first.
    Yeah, in cold climates people rely on heaters to keep their vehicles from freezing up. Back in the old days people up here in Alaska would drain thier oil every night, take the can of oil inside, the next morning they would heat it up on their wood stove and take it outside and pour it back into the engine. This would thaw everything out and ensure a good start.
    The extreme cold (even heat) will ravage your vehicle if you let it.
    Some tires that didn't have enough natural rubber in them would freeze, shrink and break the bead seal. So then you would have to take your wheels off every night when it got cold, only to install them in the morning again.
    Now we have block heaters. The one for the 01/02 corolla is like a 1/2" round x 2.5" long aluminum cylindar looking thing with a metal clip on the top and a cord coming out of it. Also they make these rubber heater pads and you glue them onto your oil pan and trans (or trans fluid pan) with RTV sealant.
    The best way is to plug into an automatic timer set to come on 3 hours before you start your car in the morning. This saves some money on electricity.
    They say, 20 or below, plug it in. You notice a big difference in starting in like -15 or colder.
    i wanna see this plug under the radiator!!! is it in the 98s also?
    statik New Member
    It is an optional accessory, most cars now have a space in the engine block for a heater.
    It's just like a regular extention cord, usually zip tied to the underside of the car...
    This is a relatively new application... you might find it a little amusing.
    http://www.arcticleash.com/
    Everyone in Alaska has probably "invented" this idea. :p
    But only one person actually did something...
    DC Stewart Guest
    I simply installed a battery warmer ($20 at WalMart) and it worked great.
