big brake kit?
Discussion in 'Stop, Drop & Roll' started by Myamaguchi1, May 6, 2004.
    Myamaguchi1 Guest
    does AEM make one for 01?
    02RSX Guest
    on their website, tehy only have them for 03-04, so i'm doubting it. tehy might, and just haven't updated their website, but i doubt they make them.
    If only corollas came wiht 4-wheel discs....
    don't tease...that would be SUCH a beautimous thing...
    02RSX Guest
    does the XRS retain rear drums?
    that'd be soooo ghey if it does.
    sean2sean Member
    so cal
    um... custom one?
    well its by fastbrakes.com
    they make it for our cars now...
    works so much better now...
    02RSX Guest
    big brake kit?
    anyone using a big brake kit on their corollas?
    what brand, and how do u like them?
    RacingSolution New Member
    AEM Makes one... and Sean2Sean has a custom one done.
    cworkm Guest
    If your talking about the Corolla XRS, it has 4 wheel disc.. at least the one i saw at the car show did...
    bimmernut Guest
    Send a PM to hooolala... I know he is using a "big brake" kit
    sean2sean Member
    so cal
    um... well... if im correct... david is just using a caliper extender bracket and a larger rotor... and ss brakes lines... have a larger rotor doesnt really do much... it just adds weight... cuz the one he is using is a 1 piece...
    the 12.2 inch rotor i have... has the same weight as the stock 10 inch rotor...
    on our stock calipers... its only 1 piston... compare that to a 4, 6, or 8 piston caliper... ull notice a huge difference...
    just my .01.
    Fox New Member
    Under your sink.
    before the forum closed down, i did get to read someone trying to modify a rear disk conversion from a celica.. cant remember who it wuz since all the treads got wasted, but thats all i can remember from rear disk brakes and my 01 rolla.
    hooolala Guest
    i did a rear disc brake covertion..
    sean2sean Member
    so cal
    yea but thats for a 03 rolla... 5 bolt pattern...
    btw, david... did u get my voice messages?
    let me know..
    sean2sean Member
    so cal
    fastbrakes.com
    JDM COROLLA S New Member
    brake kit
    I have an aem brake kit on my 2003 works great! Reduced stopping distances by far. Highly recommend them, plus they look tight when you have some nice 18's behind them.
    rear brake kit
    RedAE102 New Member
    Cypress, CA, USA
    Rear discs definitely help my car stop better. The calipers have been replaced, and are now very rusty, but then again, I did it for the SAFETY factor, not for looks. If you're going for looks, you're doing it for ALL the wrong reasons... Besides, rusty calipers beat painted drums any day!
    Fox New Member
    Under your sink.
    what year is your car? and how did you get the rear disks ?
    lonelydriver New Member
    Hooolala sells a rear disk conversion kit at vpower.
    02RSX Guest
    looks like a 93-95 to me. his name is AE102, so i'm almost sure it's a 93-97 at least, but it looks like a 93-95 DX
    Le Racer Guest
    Rear disc brake is a good idea
    but you also remeber your tires do alot as well
    So upgrading brakes without tires is pointless
    Fox New Member
    Under your sink.
    yeah but thats for an 03+ corolla , i need a 2001 rear disk convertion :p
    dammit... why do all the good things come for the 2003+ corolla's, us 01-02 rolla owner get hated all the time.
    sean2sean Member
    so cal
    im gettin one made... it will be out pretty soon... maybe in a month or two... by fastbrakes.com
    Fox New Member
    Under your sink.
    for how much?
    Please follow up on this... and give us the feedback on them afterwards, id be one (ad probably not the only one) to order them right away after u give the go.
    sean2sean Member
    so cal
    the owner is debating if he should make a full kit or a partial kit...
    full kit will include, brackets, ss brake lines, calipers, pads, rotors, and e brake lines.
    partial will only include bracket, ss brake lines... you will need to get the calipers and e brake lines... etc...
    something like that... it will be out pretty soon... so stay tune...
    and just by changing my front brakes to 12.2 inch rotors and 4 pistons calipers... and ss lines... i noticed a 50+ percent increase in firmer brake pedal feel. 60-70% less effort needed to engage the brakes. before i would need to step the pedal about 1/4-1/2 way before it will start stoping... but now i bearly need to tap it...
    in short... it brakes awesome!
    and no, i do not lock up my brakes... i dont really know how to explain the feelin... but go try drivin a car with bigger, better brakes... and ull know wut i mean... it brakes better then our avalon and 02 camry... and 98, 96 camry... and way better then our stock 02 rolla...
    sean2sean Member
    so cal
    no abs... i didnt get that option... there was only 5 02 rolla S left on the lot...
    Fox New Member
    Under your sink.
    u got ABS?
    Pantaloon007 Guest
    What is the price for the 93-02 style rear disks? Parial sets would be sick, Id just upgrade my rears and BADDABING damn that will delete tenths at the track like mad. Makes me very happy inside :p
    rolla02 Corollalcholic
    Delaware
    Hooolala has a 03 man, there is no 02 rear brakes yet
    sean2sean Member
    so cal
    still workin on it... when u see/hear my car have rear disk... then thats when it will be out....
