Engine Best nitrous brand for 98 rolla
Discussion in 'Powertrain' started by GSE21tuner, Jun 2, 2004.
    What would be the best brand of nitrous for the 98 rolla? I only wanna get maybe another 40-50 hp. Which is more cost effective, and which is easiest to use?
    slvr2000fdvspec Guest
    zex has easy install kits..pretty sure they're good, but you always got NOS or NX
    you can't get a nos kit, i hear good things about nx wet kits tho
    corolla_man_j Guest
    ask zexprism ...hehehehehe
    02RSX Guest
    really, they're all good.
    Zex is considered teh easiest to install, but i've heard NX nozzles give a better gain, even though they're supposedly teh same shot.
    what kinda set-up are u goin for though, wet, dry, or DP?
    CadetLee Guest
    I've had an NX wet kit for months, but I haven't got around to installing it yet.. :eek:
    that sounds like an interesting setup...
    02RSX Guest
    DP = direct port. i don't know much about it, the nitrous forum of clubrsx is really good info, but u can't use the search button unless u're registered, which is ghey
    02RSX Guest
    hehe, i was gonna say that earlier, but decided to be helpful instead
    I'm looking for a wet system. They're the best overall.
    HaPpYfAcE New Member
    Tucson, AZ
    zex kits require the throttle to be wide open and there's somethin else that someone was tellin me about them that they didn't care for....
    might be a good thing that the throttle is open....s'up to you, i spose.
    Pantaloon007 Guest
    You think about selling it? If so, Im very interested- Im gonna go that route, then get a Scion tC at the end of the year...
    02RSX Guest
    ROFL!!!
    CadetLee Guest
    Direct port on a Corolla would basically be a nitrous line into each pipe on the intake manifold, just before air/fuel enters the engine. If you run too high of a wet shot, you run the risk of more n2o/fuel/o2 in some cylinders than others..direct port avoids that.
