Engine best engine to use for 90 corolla gt-s cpe
Discussion in 'Powertrain' started by 98tealrolla, Oct 13, 2005.
    98tealrolla New Member
    What would be the best engine to use for a 90 corolla gt-s coupe just dropping it in. Same mounts, exhaust hookup, ecu, etc. No modifications.
    That already has a decent engine to start with - 4AGE. I'd just stick with that and mod that motor (more gains from working the original motor than costs associated with swapping in a more powerful engine), unless it got toasted.
    ctam1986 Chicken
    Orange County, CA
    reallly true! if your engine has lot of mileages then rebuild it and throw a turbo in it man
    the 3sge bolts up to the stock tranny...the 3sgte should, as well...
    I found this used 90 gts 5 speed that im thinking of buying.... only has 123k miles which isnt bad for a 90 considering I have about 127k on my 98 lol.
    turbo4age Love to Hate me
    NV
    toyotaspeed will correct me if im wrong.... but the late 90' and the 91' gts corollas had the highcomp 4age.... a very solid building block to begin with. if your 98 is a 5 speed the 90 might be able to keep up in a straight line, but in the corners and overall feel itll blow your 98 away. pick it up, thats low miles too.
    toyotaspeed90 New Member
    Bellingham, WA
    yes.... 90-91 have the highcomp 4age.... it WILL beat a 98+ corolla (i've proven this). the smallport makes ~130chp, and factory rev limiter is around 7500.... the 90-91 also has 4 wheel disc brakes (and larger brakes than the 88-89).
    on top of this, a 4agze is a fairly simple swap.
    the handling of ae92's is more than surprising. i've kept up (and beat) many mr2's and ae86's on/off the track in handling situations... which is hard to do in a FWD car.
    thing is though.... I noticed on www.edmunds.com that the 91 corolla has the 130hp engine but the 90 corolla only has around 103hp (something like that). And yes I am going to get it even though its located about 130 miles away from me. Im still waiting for the guy to answer my email. I found the car from autotrader. Also, Im probably not going to do this, but is it possible to convert this car to all wheel drive. I noticed you can buy the parts for this.
    Bellingham, WA
    if you are looking at a corolla gts 1990, then don't read edmunds. it has a smallport 4age
    teevee247 Well-Known Member
    Montreal, QC
    Speaking of a 1990 Corolla GTS, a guy up here is selling one with 235 000kms on it, no rust on the car, but, it was in an accident, engine/radiator is good, but needs bumper/fenders/hood... tempting car...
    It has:
    eibach pro kit springs
    KYB struts
    2 1/4" exhaust
    ceramic coated hedders
    brake calipers rebuilt
    new clutch and master cylinder
    Hes asking $1300 CAD Neg. (About $1100 USD)
    yeah, that's not worth it. :)
    Montreal, QC
    Yeah, I know :( But damn, I love those cars... if I could get it for $750, I probably would...
    i like the color
    Bellingham, WA
    that isn't worth $1300 cad
    i personally wouldn't buy it for any more than $500 us
    eh...crashed? $300 tops.
