battery light coming on when bass hits
Discussion in 'Interior' started by DrunkSaru, Apr 16, 2007.
    sounds like your stereo is eating up too much juice. i dont know what your setup is like but consider a better battery or better yet, a separate battery for your sound system.
    fuzionrolla Guest
    low power from the alt or low power in the electrical's my guess is your lights are also dimming pretty low and your tach needle is lowering in rpm's witch means your taking too much power and you will kill your alt.
    corolla81386 New Member
    I just installed my subwoofer system and when the bass hits really hard sometimes the battery light (which I didn't even know existed) comes on for a split second. Does anyone know exactly what this light is for and what causes it to come on?
    do they even make bigger alternators that will fit the car? I've never really checked cuz mine never went bad.
    cgreen38 Common sense, p
    Baton Rouge, LA
    Get an Optima Yellowtop battery and find a bigger alternator.
    fuzionrolla Guest
    yeah i have two 10 inch kicker L-5's and they are hitting between 140 to 147 db's witch is loud and its giving me problems with hearing soo either get rid of them or wear ear plugs when i pound them
    I already have an optima yellowtop and an upgraded alternator
    Baton Rouge, LA
    What size fuse?
    And for God's sake: what the hell kind of system do you have? How many amps are you trying to push?
    do you have proper grounding as well?
    300 Amp fuse, 1 subwoofer 3200watts rms.
    The voltage stayed up at around 14 volts when the light came on so I'm assuming it doesn't depend on voltage. Is it because of current draw?
    Baton Rouge, LA
    Dude, you need a second battery or something. That's a metric fuckton of power you're trying to push.
    fuzionrolla Guest
    wow i thought me having 1800 watts in a corolla was stupid what are you trying to do to yourself
    i like bass
    Baton Rouge, LA
    You hate having glass in your windows and being able to hear. :eek:
    lol it's just one subwoofer but yeah its kind of rediculous sometimes
