Engine ATTN: Bzzan, C-Rolla, J Yota. Mid pipe is not exact fit.
Discussion in 'Powertrain' started by Blk03Corolla, Jun 21, 2004.
    Blk03Corolla Guest
    OK well ran into a small problem today Im having everything installed on the car and the mid pipe isnt a perfect fit. Where it connects to the axle is slightly different on the Corolla than Matrix. Right now it will run fine but will have some raddle. I will let you know how bad when I get to drive the car. The shop doing the install is going to make get the necesary parts and weld it to make it work so be aware of that. i will post the how to fix aswell when they get it done. Now I will post this in another thread but I Really Really need someone to go to Jp Performance in Santa Ana to let them look at your car and how to fix the mid pipe so it will be a direct bolt on with no issues. I would greatly appreciate it as will all of the members who would like to do this mod. Jp is the only company out there actually doing a lot of exhaust work for our cars and need this to make everything right.
    imported_j_yota Guest
    Thanks for the heads up. Keep us posted.
    ultraviolet Guest
    Do you think the fit problem is only with the Corolla's?
    I havent heard any of the Matrix guys having this problem.
    c2300 Guest
    PM'd you.
    bzzsan Guest
    sonofa...
    Blk03Corolla Guest
    just so you guys know it fits and I could barely tell there was a rattle jp will probably end up coming out with something that can be welded on to make it a perfect fit and in that case you could fix it then. I took so many people around in my car last night and no one could tell. Oh and with 3 pretty good size guys in the car it still pulls hard. I could not believe it before when I added weight it made a huge difference but now it seems like it doesnt even fase the rolla
