Engine Anyone try an aluminum flywheel?
Discussion in 'Powertrain' started by jpbartosch, May 14, 2004.
    jpbartosch Guest
    I've been looking at Unorthodox Racing flywheels for awhile now. They're a bit on the pricey side, however the flywheels are 2 lbs. lighter than TRD (8 vs. 10). I have a UR crank pulley and I think it's great quality. Anyone install a different flywheel or a UR flywheel?
    mixalis Guest
    No, but I have been looking at the same thing. Not sure if it's worth it though. Let me know how it turns out for you if you do install them. I do remember someone in an old thread that I read saying that he did install an UR flywheel with a stage II clutch and it was an awesome combination...but, that's all I have really seen.
    RunicSabre Guest
    I have a Clutchmasters aluminum flywheel, but I had to modify it to install it. You see, I had to extend some of the holes to properly align the bolts to secure it to the engine. I've got the stage 3 clutch kit from Clutchmasters too.
    What I've noticed since the install were quicker revs and acceleration. I would recommend getting either that Unorthodox, Fidanza, or the TRD versions because they probably FIT. I bought my flywheel from NOPI and it said it was for my 98 Rolla...don't waste your money on them.
    RunicSabre Guest
    What year does he have?
    jpbartosch Guest
    Thanks much! I'll probably spend the cash and go with a UR flywheel and clutch.
    toyotaspeed90 New Member
    Bellingham, WA
    don't go too light.. otherwise the car won't be streetable
    RunicSabre Guest
    No prob man. Good luck on the parts. You'll like the results.
    LowRolla Will work for turbo
    Oviedo, FL (orlando)
    cadetlee has a fidanza flywheel and im not sure what clutch - PM him, he could tell ya
    CadetLee Guest
    I have a '98 and an ACT clutch (heavy duty pressure plate & organic disk). It's great. :D
    RunicSabre Guest
    Right on, so do I. Kick ass. Love for the 98-00 crowd.
    jpbartosch Guest
    I've driven a 2004 S60-R and a 2003 M3, it can't be any harder to drive than those transmissions. If you don't give 'em gas they'll stall faster than you can blink.
    HighRollN95 Guest
    how do you find the different levels of the flywheels? I have a stage 1 clutch masters clutch in my 95..i want a stage 3 (bought mine from Nopi as well) but what would be good for like street wise and some drag strip racing?
