anyone no how to install vac&temp gauge?
Discussion in 'Interior' started by yngrolla, May 2, 2006.
    yngrolla Guest
    anyone no how to install a vac gauge and a temp gauge in a 00 rolla?
    yngrolla Guest
    yngrolla Guest
    yngrolla Guest
    soemone anyone HELP
    nocpan New Member
    what kind of vac/temp guge? and where do you want to mount it?
    yngrolla Guest
    i dont no what kinda gauge it is but its for the pillar i have a dual gauge pod i bought the gauges off phonzestone i think was his name on here,
    nocpan New Member
    ok temp gauge you can tap the signal wire for your stock one on the dash or you can mount a sandwich adapter on your oil filter and install the temp sensor there, do you have a temp sensor?
    I'm not sure what you mean when you say vac gauge, is it Air Fuel ratio gauge? Oil pressure gauge? or something different?
    If you want to mount them on a pillar then just pull the pillar off (plastic part) use 2 or 4 screws to attach it run the wires out to the inside of the pillar and you probably will need to drill a small hole going into the engine bay its no biggie just used a regular drill and make sure you don;t drill anything else but the firewall in the car
    R1dg3xrac3r Guest
    SPlice wire from the coolant temperature sensor, and route it to your dash. Same thing for oil temp. Air/Fuel ratio meters, you do the same thing splice wire from the O2 sensor and trace the wire back to where ever you want to mount the gauge. No point of monitoring these 2.....they rarely go bad.
    turbo4age Love to Hate me
    NV
    vacuum is a useless gauge. basically how to tell your fuel mileage... less vacuum less fuel mileage. for temp you just find a source. is the temp gauge electronic or mechanical? if mechanical there should be a bung on the block somewhere that you can screw the sending unit into...
    you have to be more specific
    yngrolla Guest
    sorry but look at the post date this is old!
