Anybody running +38 offset?
Discussion in 'Stop, Drop & Roll' started by JspeXAE102, Dec 1, 2004.
    I need to update my order tomorrow.. I origionally wanted 15X7 with a +43 offset but apparently they been discontinued. Now i'm left with either
    15X6.5 +38, +43 offset
    15X7 +38 offset
    I really want the 15X7 but if it mean i would have rubbing problems, i'd rather pass and drop down to 6.5's
    http://www.rayswheels.co.jp/cgi-bin...i?modelName=57C
    i'm currently on a TRD Japan/Tokico setup, 3.2/3.0 FR Kg/mm spring rate. I will be upgrading to Tein dampeners with at least a 6/4 FR Kg/mm spring rate. Tires will be staggered 205mm up fron 195mm in the rear.. all 50series. I'm thinking of running the new Azenis RT615 as soon as they're released and Ziex 512's in the rear.
    rolla02 Corollalcholic
    Delaware
    I have 17x7 with a +40mm offset and no rubbing and I am dropped 1.75 front and 1.5 rear on blown stock struts and no rubbing.
    Hope that helps you a little bit
    Corolla DX-R AE100
    Vancouver, B.C.
    i'm running 15" X7 w/ 32 offset hahah no problem after rolling my rear quater
    What size tires are you running 195/55/15 or 205/50/15 or something else?
    vlad7 Guest
    whats the offset?
    turbo4age Love to Hate me
    NV
    CadetLee Guest
    I run 185s on my 14x5.5...I'd imagine it's at least 205 for a 7"..
    NV
    all with +40 offset?
    I wonder if i can get 225's on 6.5" It'll be nice if i ever decide to mount some hoosiers or avons
    superpilun Guest
    In my opinion, the car looks right with a 35 offset. Anything else and the fender looks like it's sticking out. You might need to roll/cut the rear fender with 35 offset though.
    vlad7 Guest
    Thanks for your help!
    Corolla DX-R AE100
    Vancouver, B.C.
    195/55/15 but my next set is going to be 205/50
