Engine any fx16 gts here?
Discussion in 'Powertrain' started by thatguy, Jun 3, 2009.
    thatguy New Member
    florida
    any fx16 gts here?
    as title says wheres the other fx owners at?
    Ares Active Member
    Houston TX
    ae82 here... unfortunately with single cam... I just returned from a 2 month vacation and started her up today...
    some details:
    around 50k miles
    springs/shocks need change
    inner/outer tie rods need change
    leaking tranny
    overheating (probably new fan switch and coolant temp sensor would fix it cuz i have new radiator, thermostat, and water pump installed with timing job)
    ac needs freon
    paintjob and VERY minor body work
    other than that, she's priceless. for a 21yo car mine is very well maintained. pix up tomorrow..
    thatguy New Member
    florida
    where are the pics at man? lol
    Ares Active Member
    Houston TX
    you should have used the search button o_O
    Here are fresh ones... Just replaced rear spring/struts
    thatguy New Member
    florida
    nice but needs a drop
