any advice? broken bolt problem... help
Discussion in 'General Discussion' started by 98tealrolla, Aug 20, 2005.
    98tealrolla New Member
    I have a small problem if anyone might be able to help with any advice. I was trying to tighten some bolts underneath the car under the engine comparement and broke the bolt head off so the bolt is flush with the surface. Any suggestions as how to remove these bolts.
    Silver_Nitrate New Member
    you have to drill it out.
    jtweezy New Member
    Irving, TX
    1.spray WD40 on the bolt
    2.Use a drill and try to drill close to the edge of the bolts center
    3.AFter drilling try to loosen the bol out of there by just turning it with you hands....
    I did this with my caliper bolts.....I broke it too, so i just did this and it came out .....try it
    Barnacules 100101101011011
    Duvall, WA
    I broke a bolt on my ebrake once, I fixed that sucker by drilling out and jamming a buncha screws in the hole until it stopped moving :) Most ghetto fix ever but it still works to this day ;)
    if theres enough sticking out you could turn it out using a vice grip.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    get a dremel and cut a line across it and use a flathead screw driver to get it out
    xnevergiveinx New Member
    north royalton, oh
    either drill it out or get that craftsman boltout kit thats really expensive. or, get a counterclockwise threaded screw, drill in a little, screw that in there and it should pull it out
    Duvall, WA
    Duct tape C4 to the base of the bolt and blow it clean though the frame.
    now thats what im talking about lol..... I was trying to screw in the bolts that hold the splash shields from the bottom of the engine
    asn13oy Stepping Stones
    OC, CA
    :eek: You broke off the bolt head just trying to tighten down some plastic??
    JLee TD05 3SGTE
    NH
    I've broken at least two or three of mine..they break way too easily - but I think mine were a bit rusted. Also, IIRC, they broke when I was trying to remove them..
