Antenna Question
Discussion in 'Exterior' started by D_Evilz, Feb 17, 2004.
    D_Evilz Guest
    Antenna Question
    has anyone totally removed the antenna...like not jus the unscrewable part...the antenna base also....does ne1 know how its on there...it sorta looks like its on there wit the same glue that the emblems are stuck on...does ne1 know if u can use the hair dryer and dentelll floss method 2 take it off
    WebMasta33 Guest
    Best way to check would be to pull back the headliner.
    I would assume it's bolted on there from underneath, but I don't know.
