Engine Annoying Clicking noise from my CAI...
Discussion in 'Powertrain' started by DVST8, Oct 17, 2004.
    DVST8 Guest
    Im sure this is not the first time you've heard someone bring this up but, I never had this Clicking noise when i first got my CAI installed @ Toyota. But it's been 2months now and It's soooo distinct when im idling at a red light etc.
    Im sure it's normal to a certain extent but if im wrong pls fill me in.
    Is there any way to Shut it up? hehe...thanks.
    Monster1ZZFE Guest
    yeah thats normal. with AEM and probably TRD the use a bracket that bolts up next to the fuse box. What your hearing is the pipe viberating on the nut that "holds" the intake tube in place. I normally get it the worst on when I start my car, and at idle on more of a down hill then anything else. Other than that I do not normally get anything. I am going to replce the item that comes in the AEM intake, its not very efficent. I like all nice and quiet myself.
    CorollaULEV Guest
    The ticking noise I had also with my AEM CAI. On my '03 it was caused by the EVAP VSV. The stock setup has it secured to the plastic airbox, so you don't hear it as much. With the CAI, that VSV is mounted to the bracket supplied with the CAI. There's no sound insulation since it mounts directly to the frame and you hear it more distinctly. Common thing with aftermarket intakes for this car, but normal nonetheless.
    Trav
    I have a short ram in my 94 and I get a noise that's similar. It usually happens when I'm on the highway decelerating in 5th gear. I figure I'll tighten up the hose clamps on the intake and try to shift it's position some, so it won't rattle against anything. If that doesn't fix the noise, then I don't know what will.
