amp
Discussion in 'Interior' started by Rolla95, Aug 2, 2005.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    amp
    i was tryin comething different with my amp...well, to make the story short, i blew my fuse, then i went to put a new one in and all it does is spark and blow the new fuse, whats wrong with it??
    AE102 New Member
    did you disconnect your battery before doin whatever you're doing?
    and uh...relay?..
    rice cracker VVT-i's Cracker
    Sacramento, CA
    what were you doing that made it blow in the first place?
    LoSx New Member
    is ground touching the 12v somewhere?
    thats what usually causes it... are you putting the fuse in with the radio off and the amp off... ie the remote wire has no power?
    check to make sure the power and ground dont touch!...
    what kind of amp is it... if its something with the amp and the amp is expensive you can get the amp repaired.... but my 1st guess would be power is touching ground somewhere
    no wires are touchin anything...the remote wire as a switch and the switch is in the off position
    and the radio is off also, the car isn't even one when i do this...key is not in the ignition
