altis lip question
Discussion in 'Exterior' started by ph0bi4, Jan 30, 2004.
    ph0bi4 Guest
    altis lip question
    i got hit by a woman not long ago, and need to replace my rear. i'm considering going with the altis lip instead of back to the molly designs, however, i need to know how much modification is needed to install the altis rear. does anyone have any experience? thanks in advance.
    OC Rolla Guest
    I haven't installed the molly designs or altis kit but I have installed the stock S kit. It is definitely possible but you have to take your time and make sure everything lines up. It took me a while to finish everything and I wanted to rush things a few times but I'm glad I didn't. Maybe someone who has actually seen/installed the Altis kit can give you better help.
    nakanari Guest
    OC:
    how u install the side skirt on CE????bc i will be install full drifter kit bymyself.
    the question of cd bc our front has door fender but rear doesn't!! SO I not sure how
    u can attach the skirt in the rear...
    thanks.
    tony
