alternator
Discussion in 'Interior' started by shortys408, Nov 7, 2004.
    shortys408 Guest
    alternator
    im running a boss 1200 amp 2 channel, im running at the most 150 watts x2. would this void my alternator warranty? and if i took the system out could they proove i had one?
    oxymoron Guest
    Well, that kind of power isn't going to hurt the alternator at all. Are you sure the alternator is dead?
    shortys408 Guest
    no im not sure, but earlier this week i left my interior neons on all night and hte stock delphi battery was dead. I got it jumped and it lasted a whole week. then on saterday it just died for no reason, so i got a new battery.
    oxymoron Guest
    It's probably just the battery. If you discharge a battery deeply enough it'll never really come back no matter how much you charge it. If you have a voltmeter, measure the voltage accross the battery terminals with the engine speed at 3000 rpm. The voltage should be just a bit over 14. If it's less than 13 or more than 16 then you've probably got alternator problems.
