alignment kit or camber kit
Discussion in 'Stop, Drop & Roll' started by valr76, Jun 29, 2004.
    valr76 Guest
    what is the difference between them...just dropped my car 2"...alignment kind of off...2003...umm...do i need either of them?
    gotarheels03 New Member
    yes you need to get an alignment. and yes you need a camber kit.
    LoRolla Guest
    I've talked to a few shops and they told me that if I lowered my car I would need to get an alignment kit but as for the camber kit I wouldn't need it unless I dropped my car more than 2.5" but even if the car is dropped less than that it is always good to get a camber kit anyways!
    BLADDER_MASTER Active Member
    FL
    If your car veers to a certain side when you have the steering wheel straight, you need an alignment.
    If your tires look like this: \ You need a camber kit to make it look back to this: |
    you should always get an alignment after having the car lowered.
