Air ride suspension
Discussion in 'Stop, Drop & Roll' started by fastswimmerguy, Aug 22, 2006.
    fastswimmerguy Member
    So Cali
    Air ride suspension
    Would air ride suspension be good to put on an 02 corolla s? does anyone know how much it would cost to have it installed? or where in so cal it can be installed??
    its_ikon FIRST widebody
    Henderson, NV
    cost will vary depending on the set up you want to go with. i would lean more towards an air cylinder instead of bags. cost could range from 1500-3000 depending on components used and what you are looking for. if your looking for a place to get a install, go to a local truck show and there will be plenty of vendors out there.
    Barnacules 100101101011011
    Duvall, WA
    It would add quite a bit of weight to your car too.
    corollakustom j-rolla what?
    Lake County FL
    Dont even mess with air cylinders go with a strut bag setup on the front and weld in a four-link setup in the back with regular bags.
    So Cali
    does anyone know the exact air kit id need? and where in so cali would they install this? i went to "pimp my ride" GAS and they dont do air kits for cars. disappointing.
