Engine Air Intake: Short/Ram vs. Cold
Discussion in 'Powertrain' started by Silver Bullet, Dec 21, 2004.
    Silver Bullet New Member
    I know this might be a nooooob question but anyway:
    What are the major ups and downs of air intakes? Is it a mistake to get a short intake?
    What type of performance gains can you get on a n/a 1ZZ-FE?
    d_samurai Guest
    ok it kinda goes like this:
    SHORT RAM
    Pros: Gain some power up in mid range to higher rpm, some torque gains (very little here), Awesome sound, better gas mileage, engine may be more "rev happy"
    Cons: Loose low end power, installation (sensors and all), noise...
    CAI: Pros- better high end power than short ram- especially when coupled w/ full exhaust system,
    Cons: loose even more low end power, water hazards, gas mileage may suffer depending on many things, run very rich on the gas mixture...
    if you dont have any other mods- i would definitley go w/ short ram- easier to install, and not so many problems..
    JDMlt3 Guest
    Well done.
    Thanks d samurai. It sounds like short ram is for me since this will be my 1st engine mod. Does short ram cause sensors or CEL problems?
    Also, how will short ram work with a catback?
    red 03 corolla s Guest
    forgot to mension that Cold air intakes it takes longer for the air to go to the Trottle body. kills your low end power compaired to a SRI
