Aftermarket gauge problem
Discussion in 'Interior' started by DJR, Jan 8, 2006.
    DJR Guest
    Hi guys,
    I recently installed some autometer gauges on my 95. Oil pressure is working fine, voltage also, except for water temperature. I've placed the sender by a water drain bolt on the block and I get no readings at all. I checked the sender's ground and it's good. The gauge itself works. I took out the sender, grounded it and tested it with some boiling water on a pot outside the engine and the gauge reads fine, at least the needle moves to around 100F. The problem starts when I have it installed, the needle won't move, it stays at the rest position.
    Any suggestions??
    Might cost a little more money but you could try using a upper radiator hose adapter.
    BTW I like your front bumper, much better than the ones we have here.
    alby13 New Member
    mmmm good way to test the gauge.
    i am perplexed.
    DJR Guest
    Problem fixed. Was a bad sending unit.
    alby13 New Member
    how did you explain it reading during your testing?
