After DRL Disconnect
Discussion in 'Exterior' started by kriskraut, Feb 12, 2004.
    kriskraut Guest
    I was planning on disabling my DRLs this weekend by using the method with the switch. I wanted to ask those of you have already done this, what is turned on when the new switch is turned off (drls off) and the light controls by the steering wheel are turned on one click. What I am going for is to have the DRLs off and the amber side markers (turn signals) on. Am I lost? Any Help?
    DaChozn Guest
    Once you have done the switch mod it should work as follow: One click = side markers turn on. Two clicks = Low beams turn on. Got it? High beams operate as always.
    kriskraut Guest
