Engine aem pulley kit?
Discussion in 'Powertrain' started by wikitrolla05, Oct 15, 2005.
    wikitrolla05 Guest
    aem pulley kit?
    is the aem pulley kit worth the $100??? How much hp/tq does it add?
    ted96corolla Guest
    i dont know but i wouldnt expect much no more than 2 or 3 hp
    corolla_racer Guest
    what year corolla do you have???...People with the 1zz says that pulley are not good for stock car....Like if you have turbo or somthing like that it will work rigth...correct me if i'm worng anyone...Cause i have been told that it can blow the motor......
    ted96corolla Guest
    your thinkin of the crank pulley aem doesnt make a crank pulley because they say you remove the vibration dampener when you install aftermarket crank pulleys but the aem kit only has the accessory pulleys so its completely safe those crank pulleys are fine if you have forged pistons and rods anyway
    Surnom Guest
    Found mine new on Ebay 60$. Might not be worth 100 but 60$ is not bad
    Drummer426 Guest
    i have an 03 s with the aem pulley. ....ya didn't notice much. Looks nice. Couldn't really tell any improvement. I also got mine installed the same time as my motor mount inserts...that's what i noticed the most...the freakin vibration..lol
