Engine AEM Bypass Valve for CAI question - ???
Discussion in 'Powertrain' started by LowRolla, Jun 16, 2004.
    LowRolla Will work for turbo
    Oviedo, FL (orlando)
    Ok, so my AEM CAI came today. I have to wait a few days to install, as I am not allowed to work on my car in my apt complex, and my friend who has a garage and is going to assist is out of town. So I'm looking through the instructions and it shows a picture of the intake installed, and another with a bypass valve installed - which is recommended and I will definitely do - as this is south FL and it rains a lot here in summer.
    What I don't understand is - where they show the bypass valve installed (just past the MAF hole) - there is absolutely no opening in the intake tubing. How the hell would a bypass valve work there? Do you have to cut the damn intake? The instructions are incredibly thorough everywhere else - on this part it just says "install a bypass valve." Helpful huh?
    So, help me out - how the hell can you install a valve on a solid piece of aluminum tubing?
    the bypass valve works like a silicone coupler, you place it between two pipes, if you dont have 2 pipes, you must cut one in half. Also install it before the MAF becaust it essentially is just a filter
    d_samurai Guest
    could you just attach the filter itself to the bypass valve? it may be tricky-but im sure its do-able.
    Mike4831 C-Town Pimp
    Statesboro, GA
    if the pipe isn't two piece you will need to cut it. but install it first. and find the best sutible spot for the bypass.
    wow that's a real pain in the ass. thanks for the info though.
