ae111 rear disk brake parts
Discussion in 'Stop, Drop & Roll' started by Vibe, Mar 10, 2007.
    i have this conversion on my 01 corolla. how do i order replacement parts for this? if i cant buy the replacement parts domestically, can i just use the redrilled '95 celica gt rotors/calipers from dr. tweak's kit? can i use the same brake lines from the ae111 setup?
    bump
    if anyone needs japanese parts - there is a guy who has set up a distributor account that can get jdm parts imported on toyotanation.com. look for him under For Sale - Auto Parts
    dward3 Well-Known Member
    Phoenix
    how do you know if your rotors need to be replaced?
    i'm just gonna keep at least a spare or two lying around and have em' inspected whenever i rotate or something
    almost everything from the ae101/111 rear carrier can be interchanged with those from the AE92; caliper, pads, brake lines, wheel bearing. The one exception is the brake disc, the ae101/111 has a 266mm rear disc, i think the ae92 has something like 242mm. The full thickness is 10mm, the min thickness would be 8mm. You check the thickness with a micrometer. The rear disc has to be imported, they are widely avaliable in Europe, Japan, South Africa and Australia so they're not too hard to get.
    01rollas New Member
    Actually just about 99% of the Levin/Trueno parts will fit our car. i know that for a fact why do you think im going through hell getting parts. Thats because they are not expensive but some are hard to find. Thanks to the USMC im stuck here for a 1 1/2.
    i'm gonna try to get the parts from fensport. anyone know another english site outside north america?
    01rollas New Member
    were you the one that contacted me a while back. or was that someone else? i know what you are looking for simply because i found them for Vamp and Hazer already. i just need to ship them out to em'.
    yes!!! lol
    how much would ae111 brake pads and rotors cost, shipped to ny 13760?
    01rollas New Member
    well right now i just got off of work and wednesday i will be off so hopefully i will get back to you by then. other than that hit me up on tuesday your time.
    thanks man, will do.
    01rollas New Member
    right now im at work and i will definately try to get you a price quote by tomorrow since i will be off then hit me up on my myspace. since i check that more often than anythng else.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    Just let me know when you get the rotors. The motor's almost done, so I'll be working on the brakes next.
    SD_S New Member
    SF, CA
    Hey, could you help me get a set of AE101 rear rotors for my car as well?
    thansk!
    01rollas New Member
    OK since i went to the shop and they basically told me for the right price they will get you basically anything you want. now what I need to know is who needs what and how many so i can go and give him the list and he will send them out to you and as far as funds are concerned i will give you the P.O.C. (Point Of Contact) and you may speak to him directly, he is legit since he works on the same base i am stationed on and i already checked him out so he is clean and good to go. You can hit me up at the following listed below.
    rurodriguez214@yahoo.com
    www.myspace.com/rardz
    or you can type this into my myspace and send me a message. or hit me up here.
    R.A.Rdz.
    daCoupe Junk Collector
    Victoria, BC
    What you're saying is if I have an AE92 parts car, I can use the calipers, pads, brake lines and wheel bearings on AE101/111 rear carriers? All I would need from Japan are AE101/111 carriers, disc backing plates and 266mm brake discs. Sounds like a very reasonable swap to me. Are you still able to bring in these parts?
    pnyk33 300whp 4afte
    orlando,fla
    if you get tierd of waiting for it to come on Ebay or what ever else you can also use the 94 camry V6 rear disc. that is what i have on my corolla. almost any Junkyard will have crashed Camry`s
    Victoria, BC
    How much work was required to fit the Camry V6 brakes? Did you convert to 5 lug as well or was the rotor redrilled for 4x100?
    Graphiterolla Member
    Macon/Warner Robins, GA
    I have the levin rear disc brakes on my 94 Corolla. I was wondering where I could get some drilled/slotted rotors and some good pads.
    Des Plaines, IL
    WorldHazard Member
    Silverton, OR
    what model/year do these come from? what prop valve did u use on the swap?
