Engine acura integra engine light
Discussion in 'Powertrain' started by ShalerPunk, Jul 13, 2004.
    ShalerPunk Guest
    car went into limp mode.
    you reset the ecu.
    it should have been blinking out a code.
    SkyAce2004 New Member
    my friend has a 91 integra and recently received a check engine light. He was tryin to do a u-turn but instead, ended up in a ditch full of water. the passengerside of the car was pretty deep in water (where is airbox is).
    I test drove his car, and the thing re-set the rev-limiter to 3k instead of the 6-7k its usaully at. No water was sucked into the intake. I took his car to autozone but they didnt have tha adapter for it.
    i told him to disconnect his negative terminal for 15 mins and try the car again. Welll.... he did it and the car works fine again.
    Does anyone know what the proble could have been? Im kinda stumped by this one
    Mike4831 C-Town Pimp
    Statesboro, GA
    water inside the car is never a good thing. prob hit his fuse box.
    XS PSI New Member
    could be the 02 sensor that shorted out in the water.
    i dont know exactally what happened..i just came here to see if there was a logical explination. its not that big of a deal as its been fixed already
