acceleration issues
Discussion in 'Care & Maintenance' started by GSE21tuner, Feb 3, 2008.
    Have you done a full tune up recently? You'll want to check your plugs, compression, accessory belt, vacuum lines, and fluids.
    2000vvti Guest
    acceleration issues
    i bought a 2000 prizm 1.8 vvt-i and its acceleration is super sluggish.
    it has better acceleration at half throttle than at full throttle. it takes like 20-30 seconds to get from 0 to 40 but after 40 it will jerk a little then start accelerating quicker any solutions?, also it turns over about 12 times before it will start if it is cold or warm it dosent matter still stalls and sometimes will quickly die???
    2000vvti Guest
    oh and the only time i could get good acceleration from a stop light is if i hold the brakes down and hold the throttle 1/3rd in and on green let off the brakes then it will accelerate a little better but still not much.
    Phan Well-Known Member
    Orange County, CA
    this might sound awfully weird but i got a 85 nissan maxima that does the same thing. So i installed a intake mantifold and amazingly the problem stop.
    05 TRD SCed Guest
    rolla996 Guest
    This past summer i had a different problem. While accelerating i would suddenly lose power for a split second. It kept happening over and over again at speeds of 35 and higher. I used fuel cleaner, changed all my spark plugs with NGK ones (ideal for rolla), and changed the air filter. I also changed the oil and did something i don't entirely recommend. After i drained my oil from the car, i started the engine to remove all the oil within the block and after 2 seconds turned off the engine. Thick black oil came rushing out. Took 2 minutes for the rest of the oil to come out. The problem went away and it ran smoother than ever. I suggest u do the same, everything costs about 30 bucks if u do it u'r self.
    The following week i changed the belt and my car seriously felt like brand new. Ran like the first day.
    05 TRD SCed Guest
    <br />
    The nasty black oil probably clogged up the oil passageways to the vvt-i mechanism. If that happened, then the vvt-i won't work and could cause acceleration issues. I've heard of this happening before. I also know that you should change your oil at 3000 miles and not the 5000 miles that toyota recommends in the service guide. I honestly believe that's why so many people are having issues with rod knock, spun bearings, excessive oil consumption and so on. I change my oil every 3000 miles, never missing a beat. I also you synthetic oil, which runs a lot cleaner in the engine not to mention all the other good things it does compared to the conventional oil.
    rolla996 Guest
    i change it every 3000 miles with synthetic as well, but for one summer while i was in Vancouver, i let my friend borrow the car and he changed it with conventional oil. Didn blame him cause he didn know and still don't know why so many ppl say that u can't go back once u go synthetic but i thought that may have been one of the problems. Or i thought that water somehow got to my spark plugs when i was cleaning the engine bay.
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    I had the same problem with my car when my MAF was dirty. I remember when i got my car from my friend i was soo excited to drive it around bc it was like a luxury vehicle compared to my old one. Took it on a drive and instantly hated it. It would bogg down at every stop light and almost die. Also when i would first start it up it would run like crap for a few minutes, die and then after I started it back up for the second time it ran okay. Just go to advance and get a can of MAF cleaner. There should be like a grey can with a little red straw Its called MAF cleaner i believe and its like $6.00 Fixed my problem and my car accelerates accurately now.
