Engine A/C not working, plz help!
Discussion in 'Powertrain' started by vagabundo, Aug 15, 2004.
    vagabundo Guest
    My A/C stopped working this morning :( . The compressor is not kicking in. Checked the fuse and is ok. I think it could be a relay or something but I don't know how to locate those things. Any suggestions? Should I take the car to the dealership? Is the A/C components covered by our waranty?
    Thanx!
    lonelydriver New Member
    yes it's covered by the warranty. take it back too the dealer
    RollaS New Member
    as long as you're under 36k miles, should be under warranty. If you have a system or something that could have caused a short out, that may not be covered.
    1ZZ-ROLLA-S Guest
    You probably have refrigerant leak. There is a low pressure switch that prevents the compressor from engaging when the system is not fully pressurized. As others have said, it's under warranty if you have less than 36K miles on it.
    vagabundo Guest
    Thanx for the comments. I took the car to a friend to have checked for leaks and gas charde and it's also fine. I guess I'm screwed since my car has 46k miles on it. I'm taking it to the dealer anyways. I live in Puerto Rico and i'ts around 98 degrees around here and without a/c it's not fun driving around.
    imported_corollas Guest
    i got the same problem fuses fine and it wont even engage? and its like 110 here every day :( ill take it to the dealer and tell you whats was wrong?
    vagabundo Guest
    Went to the dealer today, they charged $50 just to take a look and find the problem. They told the the problem was the relay located inside the fuse box (part number 90987-02022). The cost: another $57. Since they didn't have I placed a special order fot it. I went to a local autoparts and got a replacement one for $12...and presto!!!... my a/c started working again. :D
    where exactly is that relay like which fuse boax and what side etc? thanks
    well the A/C has 2 relays. One is the HTR (Heater) Relay in the front passenger door jam inside the car, and the other is the MG/CLT Relay in the engine bay fuse panel(long skinny one) on the driver side.
    w1ngzer0 Guest
    corollas you live in arizona and you have green grass like that? :?
    lol no i made it greener w/ photoshop, and its not my grass i parked in a friends yard when he was at work :p
