Engine 99 corolla tranny light..
Discussion in 'Powertrain' started by coro99a, Jan 5, 2011.
    coro99a Member
    the light that tells me what gear im in is out how do i fix it??
    first check if the light bulb is out. then check your wiring. you may also have a blown fuse somewhere. search each thing ive mentioned in that order and 9 times outta 10 you'll find your problem.
    coro99a Member
    how do you get to the light though??
    take off all of the paneling inside of your car untill you get to the shifter. then unbolt shifter and check the light. its all in your chiltons manual. if you dont have one, invest in one. Its been my best friend for years now.
    coro99a Member
    naw i dont have one.. where can i find one??
