Engine 99 corolla engine swap
Discussion in 'Powertrain' started by sammy, Mar 20, 2006.
    sammy New Member
    im thinking of going with a celica engine but ive been searching and reading all day on the net and its more complicated than i thought. what would you guys suggest i rather just swap it out not haveing to change the motor mounts and harness. what newer engine should i go with i have the 1zzfe in it now
    Denver Rolla 98 impreza
    basically the only thing that you would be changing is the head going from not vvt-i to vvt-i
    but you would also have to change the harness on anything new that you put in.. the harness is spisific for that engine, and ECU set up...
    like for instance the 03+ corollas are not compatable (without changing plugs) to teh Celica ECU with VVT-i.
    why not go for a turbo system or something? more gains and actually not that much more expensive..
    sammy New Member
    hey denver rolla what do you mean stick with the stock engine and put a turbo system on it or go with the celica engine. how much difference would i feel adding a turbo setup to the stock 1zzfe would it put alot of strain on it. thanks for the reply
    Dr Tweak Mad Scientist
    Savannah, GA
    Do you mean the Celica 2ZZGE or the 1ZZFE?
    -Doc
    oppositesleeper New Member
    Oklahoma City
    the celica 1zz is no different if you already have vvt-i if im not mistaken. The intake manifold and exhuast manifold are different but thats all i believe.
    Savannah, GA
    -Doc
    sammy New Member
    i have a chance to swap my 1zzfe with a turbo celica ingine for 1500 + 2500 for labor and inter coller. the only thing is there gunna have to change mounts and harness to make the celica engine fit. i started considering buying the same engine since my 1zzfe is blown and adding pistons and a cam plus a turbo but man i know that adding the turbo 2zz would be alot more fun. im new to riceing and man theres so many options out tere so i would like your guys strong opinions
    He won't be able to do it... read the top of the post. It's a 99.
    To swap out a 1ZZ from a Celica into a 98 or 99 series Corolla, you have to replace the wiring harness and the ECU along with the motor. It'll bolt in just fine, but the electronics are all different. (Doc you've seen what goes into this putting that VVT-i motor into a 99)
    I'd suggest build out the existing non-vvt-i motor and then turbo (well duh, since i have a turbo'd 99, lol) but that's just me.
    sammy New Member
    thanks man thats what im going to end up doing just put the same engine in and turbo it. you guys have been very helpful another quick question is there a s/c for 99 corolla.
    nope - and its very hard to find turbo stuff for a 99 --- don't buy a "kit" from anyone other than Dr Tweak (if/when) his comes out. otherwise go custom and I can help you there... every other avenue has shown nothing but trouble for those who have tried them. (ie kits)
    If you want a breakdown of my setup, just pm me.
    always keeping things a secret aye trav
    heh, not really...
