98 rolla stock speaker swap....help.
Discussion in 'Interior' started by laz, Mar 25, 2005.
    laz Member
    NYC
    Drill out the rivets and get a speaker mounting kit for the new ones.
    X
    Tamago New Member
    yeah, gotta drill :) ..
    RobUpNya Guest
    i'm trying to swap my factory front speakers out and put some aftermarket components in, but i ran into a problem. i noticed that the front stock speakers are mounted on a metal bracket and there are no screws where i can unscrew the speaker. The other problem that i noticed is that the bracket that the speaker is mounted to, doesn't have screw either to take it off the door.
    how do i approach this issue? i could try prying off the bracket, but i'm scared to break anything.
    can some1 help????
    sddynamix Taybo Masta
    La Jolla, CA
    I drilled mine out, and replaced them with 6.5's. They'll fit the hole almost perfectly. Otherwise, you can custom make a mounting bracket, or i'm sure if you search around someone will make one for it.
    RobUpNya Guest
    that's the only way to get it out?
    never did that before.....how do i start? what size bit do i use?
    any1 have pics.?
    RobUpNya Guest
    any body know how big of a bit i have to use?
    what if i cut out the old speaker, and dremel the old backet out, and mount a 6.5" on the existing bracket....will that work?
    srt4me Guest
    Dremel the rivet out. Either chop the top or drill through it. It'll be kinda fun, in a wierd kinda way.
