94 prizm/camry??
Discussion in 'Exterior' started by GSE21tuner, Apr 30, 2007.
    Not at all.
    94 prizm = corolla, not camry. :)
    Projekt_Go Guest
    94 prizm/camry??
    does the 94 prizm and camry have the same body??? if yes then can i also buy camry parts for it???
    DOT. Noypi ako!
    Have you actually tried swapping the headlights?
    The civic headlight matched prizm too. One part match doesn't mean other parts match too.
    Prizm share the same engine/body with corolla. But Prizm change something here and there. That's why it's not 100% interchangetable.
    Projekt_Go Guest
    then how come the corner lights dont match with the corolla...but it matches with the camry???
    Projekt_Go Guest
    ok i stated the ? wrong...
    will the camry corner lights fit the prizm???
    cgreen38 Common sense, p
    Baton Rouge, LA
    Negative. Corolla corners should work, tho.
    Projekt_Go Guest
    well it doesnt...i bought a pair almost a month ago and it didnt fit... thats why i had to sell it..
    You should really do more research before you buy anything. That way you know what fits and how well it works.
    94 rolla Guest
    yea, just like how the taillights are completly different from the 7th gen rolla. check up on the stuff.... and also, look at the shape, doesnt realy match up all that great man... id say at most you'd be able to grab a couple of interior things, engine parts, and suspension.
