Engine 93-97 AC not working help..
Discussion in 'Powertrain' started by anguyen, May 22, 2004.
    anguyen Guest
    hey, my dad's 94 corolla's AC isnt workin. i dont know what the problem is but the led on the AC button doesnt turn on. i tink that has something to do with a solution to this problem. does any of you guys know what is wrong?
    thanks.
    ChristianVA New Member
    it can be alot of things. the pressure cycling switch. pressure cut off switch or even the compressor. you got an electrical problem.. first try to jump the pressure cycling switch. if the compressor comes on then you got a bad cycline switch..if it doesnt come on well your into alot of problems
    93corolladx Guest
    It could be a lot of things but have you taken your center console out lately? One time I took it out and the back plug in for that switch nudged itself out so the switch wasnt making a good contact.
    gotarheels03 New Member
    yup, if you did anything w/ the center console then the switch most likely isnt all the way in. (has happened to me a few times) take it apart and make sure its all the way in.
