60,000 mile service
Discussion in 'Care & Maintenance' started by wasabinuts2go, Nov 21, 2008.
    wasabinuts2go BeeP BEEP!
    Norcal
    60,000 mile service
    I have one of those maintenance log that toyota gave me. My car is about to hit 60,000 miles and some of the things listed makes me very confused. I have highlighted them in red
    it says:
    Replace engine air filter
    Replace engine coolant
    Replace engine oil and oil filter
    Replace air conditioning filter (avalon, camry)
    Replace spark plugs (camry, echo, sienna)
    Rotate tires
    Inspect the following:
    -ball joints and dust covers
    -brake lines and hoses
    -brake linings/drums and brake pads/discs
    -differential oil???
    -drive belts
    -drive shaft boots
    -engine valve clearance
    and more
    additional maintenance items for special operating conditions:
    replace automatic transmission fluid
    replace differential oil
    -Am i suppose to change the spark plugs at 60,000?? and what brand do you guys prefer/suggest?
    -do we even have a air conditioning filter? i believe we don't right?
    -is there a way we can replace engine coolant by ourselves? or do we have to go somewhere and get it flushed?
    -I believe there isn't differential oil in our corollas right?
    i know some of these are dumb questions, but i just want to do it right. I just want your thoughts and suggestions since a lot of corolla's in this forum is past 60k miles.
    Denver Rolla 98 impreza
    spark plugs depend on if you have VVT-I or not... being a 2002 you do, I would say NKG iridium plugs... yes you can just drain and fill your coolant (don't forget to burp it), we do have a front diff but its part of your trans, would say no on the AC filter but that may be a cabin air filter...
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    Cabin filters arent an option in the Corolla till 2003 so you dont need to worry about that one. As for plugs, id recommend putting in what comes out so theres no confustion.
