Engine 5sfe
Discussion in 'Powertrain' started by Rolla95, Sep 1, 2006.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    5sfe
    does a 5sfe from a 6th gen celica bolt into a 7th gen corolla? i dunno if they had changed the mounts between the 7afe and a 5sfe in the celica, just wondering cuz i can get that motor for pretty cheap
    BLADDER_MASTER Active Member
    FL
    To answer your first question, yes the 5S-FE will drop in although you'll have to modify the engine mounts. You could probably ask Dr. Tweak for some help on that since 6GC's also came with 7A-FE's and he's done several 3S-GTE swaps onto them. I mention the 3S because they have the same mounts as the 5S. What were your intentions with the 5S-FE?
    i wasn't really thinking of doin it because i dont plan on having my car for to much longer
    i was onl wondering because i can get that motor pretty cheap, and its got about 25 more horses then my car now
    gotarheels03 New Member
    LOL, that engine has totally different mounts, ecu etc. If you're willing to go through the trouble of swapping from an A-series engine to an S-series. (which by the way will be ALOT harder than you'd think) you may as well swap in a 3SGTE not a puny 5S-FE.
    Just find yourself a 4A-GZE / 4AGE instead.
